I have an odd one here. Has anyone ever seen this type of bearing
bush being used in standard Z1000-A2 fork bottoms.
It 40 OD X 36 ID X 10 mm H and is not a split bearing.
If so does anyone know where I can source them from?
Cheers Mike
Z1000-A2 Fork bush
- DogsbolloxofZ1B
Re: Z1000-A2 Fork bush
Seen these before and believe they are not available.
Try searching online using bush dimensions rather than bike model or part number. I found lower bushes at pyramid parts that fit a gpz1100b like that.
Olly
Olly
Lemmy
Lemmy
nearest i can find
https://www.motorcycleproducts.co.uk/40 ... s/1/019503
- DogsbolloxofZ1B
Thanks for info,
Z1Bman, spot in.
Cheers Mike
Z1Bman, spot in.
Cheers Mike
Users browsing this forum: tightwad and 62 guests
