Hi
I'm looking for a 82 Z1000J electronic front wheel speedo drive. Preferably unlike mine with the locating peg in good condition and working.
Cheers.
Z1000J electronic speedo drive
Re: Z1000J electronic speedo drive
As rare as tits on a fish. Best of luck.
The (normally missing) fragile, teeny weeny peg on the fork bottom leg and the hopelessly in-adequate buttress on the Hall sensor are not critical to its operation. If you have one that works just give thanks. When you tighten the sleeve nuts on the spindle it cant rotate so the indexing items are mostly redundant if you point the exiting cable up and backwards at approx 45 degrees.
Thanks, I don't seem to be getting any voltage through it.
This might help. Last post from Matt gives all the voltage tests etc.
viewtopic.php?f=3&t=44116&p=368344&hilit=oscilloscope#p368344
If the worst happens there are heaps for sale on ebay for now.
I have a Gpz1100B1 front wheel speedo drive, if it's the same item.
Sorry on the late reply.
Thanks for all your responses, I have managed to bag one.
Let's just hope it works and it isn't any of the the other bits in the system
