I’ve a Z1B I am renovating and I am trying to get the needle bearings that were put into the swinging arm, out. Yes, I wish I’d not gone down that route and left well enough alone, but alas it’s all too late.
As of now I have 4 needle bearings which I have utterly destroyed to the point where there is only the the outer shell of each left (between pullers, screwdrivers, drifts etc.) Despite only the outer race of the bearings remaining, these guys are jammed solid (though plenty of grease) into the swinging arm - I have no idea what they did when they put ‘em in. After most of the day trying I managed to get one to a point where it was sticking out of the swinging arm by about 3 mm. This is the extent of my success - none of them will move anywhere beyond this.
I am trying to avoid damage to the arm. Suggestions would be appreciated.
Thanks.
Stewart.
Jammed swinging arm bearings
- wheelysteve
Re: Jammed swinging arm bearings
I had to carefully cut mine with a mixture of hacksaw blades and dremel until I could use a small chisel to collapse the bearing shell . They are a right bugger to get out !
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Been there a couple times myself and as the man says Hacksaw blades were the only way in my limited workshop but it is possible
with patience which is another one of my weaknesses
Good Luck
Oooohh the Dremel is the man.
Thanks for your help guys. After spending a full day yesterday on these little bastards, the Dremel got them out in less than 2 hours today.
Appreciate your advice gents. Happy camper. Now, what’s next....?
- wheelysteve
Well done Stewart. Took me ages to get them out on my Z1R swingarm. The Dremel is one of my most used tools at the moment !
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
When converting from bushings to the double needle bearings on each side,or even from single to double needle bearings I've taken swingarms to a machinist to have the pivot checked to make sure it was straight,nakes life much easier when installing new bearings and shaft.
What did you use in the Dremel to get them out
wilsonsjw11
Any update on this please, what attachment was used in the Dremmel, the disc cutter?
Regards
Steve
Regards
Steve
What size are they? Wil they not respond well to something like this?
https://www.ebay.co.uk/itm/9-Inner-Bear ... 0677.m4598
Users browsing this forum: No registered users and 189 guests
