Ex drag bike back on the road
thebuelligan
Re: Ex drag bike back on the road
#16 PostAuthor: thebuelligan » Thu Jul 23, 2020 9:23 pm
Rear master cylinder from GPZ1000rx worked out nicely
thebuelligan
#17 PostAuthor: thebuelligan » Fri Jul 24, 2020 8:18 pm
Spent ages looking for a vintage AP Lockheed calliper for use on the rear and then like buses .. wait all day for one and 6 come along at once!!!
thebuelligan
#18 PostAuthor: thebuelligan » Fri Jul 24, 2020 8:21 pm
Resulted in a slight change of plan .. Originally was going to run single disc on the front but as I had a RHS AP amongst the bunch will be running a dual disc setup..
All three stripped powder coated and rebuilt ready to go!
thebuelligan
#19 PostAuthor: thebuelligan » Sat Jul 25, 2020 10:20 am
Another small job done .. Vintage MRE lock up cover polished up better that I expected for a rough sand cast piece!
thebuelligan
#20 PostAuthor: thebuelligan » Sat Jul 25, 2020 10:25 am
Going to take a look at restoring the old ATP water injection tank. The sight glass is useable but has a hairline crack that runs halfway through and Id like to replace.
Can anyone recommend a plastic engineering/machinist?
neilbarrett
#21 PostAuthor: neilbarrett » Sat Jul 25, 2020 1:16 pm
just replace with a new piece of perspex ,tank can also be used a oil tank for seperate turbo oiling system
thebuelligan
#22 PostAuthor: thebuelligan » Sat Jul 25, 2020 2:29 pm
If I have to was going to use plain piece of acrylic but like the idea of matching the original with the raised area.
Was thinking about a separate oiling system but don’t want to over complicate with additional pumps etc.. I’ll just run an additional inline filter to the turbo
Plummen1
#23 PostAuthor: Plummen1 » Sun Jul 26, 2020 6:24 pm
I like that rear master cylinder,is it easier to find a rebuild kit for that than the 80 kz1000 rear master cylinder with remote res?
thebuelligan
#24 PostAuthor: thebuelligan » Mon Jul 27, 2020 8:16 am
Plummen1 wrote:I like that rear master cylinder,is it easier to find a rebuild kit for that than the 80 kz1000 rear master cylinder with remote res?
Yep dead easy - https://www.wemoto.com/bikes/kawasaki/g ... kit_-_rear
Big Fluff
#25 PostAuthor: Big Fluff » Fri Aug 07, 2020 10:25 am
I believe this was the result of running with an incorrectly set up ATP water injection kit on a customers TC :roll:
It's the only thing I could think of that would cause this much corrosion and damage, and that's just the inlets :shock:
I junked the water injection kit and went for boost activated retard instead which helps to run cooler.
thebuelligan
#26 PostAuthor: thebuelligan » Fri Aug 07, 2020 8:02 pm
It’s the nitrous setup that I’m more concerned about lol!!
The water injection is as much about period vintage parts as is the Vertex magneto ignition..Both are pretty much obsolete and outdated but for me still very cool!!
thebuelligan
#27 PostAuthor: thebuelligan » Fri Aug 07, 2020 8:04 pm
First stab at the rear mudguard.. still plenty of fettling do but as a first run working out not too bad!
thebuelligan
#28 PostAuthor: thebuelligan » Fri Aug 07, 2020 9:37 pm
Little more fettling done
thebuelligan
#29 PostAuthor: thebuelligan » Sat Aug 08, 2020 6:55 pm
Attempt number 1 was a little busy so version number 2 is a more simplistic “Z”
See what it looks like after polishing!
thebuelligan
#30 PostAuthor: thebuelligan » Sun Aug 09, 2020 8:52 pm
Polished up
Users browsing this forum: No registered users and 178 guests
