Z1A endless chain?
MrDavo
Z1A endless chain?
#1 PostAuthor: MrDavo » Mon Aug 10, 2020 8:19 am
I’ve seen this asked in old posts, but wanted an up to date answer.
While I’m building my Z1A, if I’m going to use an endless chain, then now is the time, before I even buy the bushes for the swinging arm. What is available? I have a new standard rear sprocket, I didn’t get a gearbox sprocket with the bike.
I don’t want a split link, I know people run them without problems, and I have somewhere got a chain riveter that I used successfully when I built a CB750. However, if I can actually buy an endless chain, I need to get it now.
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
Re: Z1B endless chain?
#2 PostAuthor: ADRIAN H » Mon Aug 10, 2020 8:53 am
Not much choice out there if you're going to keep to 630 chain.
Note these are both from Germany - as UK does not seem to stock them (found this when trying to buy a chain last year) ?
https://www.biketeile-service.de/en/tra ... sv092.html
https://www.biketeile-service.de/Kawasa ... oring.html
MrDavo
#3 PostAuthor: MrDavo » Mon Aug 10, 2020 9:07 am
Thanks for the links Adrian, that will save me a lot of searching and checking.
Both chains are listed for the Z1B on, is there any difference with a Z1A chain?
1974 Z1A
z2.john
#4 PostAuthor: z2.john » Mon Aug 10, 2020 9:19 am
Z1B chain is wider due to the O-rings. If you fit this you will need the Z1B front sprocket and the spacer for the rear sprocket
#5 PostAuthor: Philippe » Mon Aug 10, 2020 10:06 am
Hi Mr Davo
have a look here
https://z-fever.de/shop/de/?cat=c151_So ... s-151.html
I order there frequently, André understands English
MrDavo
Re: Z1A endless chain?
#6 PostAuthor: MrDavo » Mon Aug 10, 2020 8:20 pm
Thanks for the link, I’ll see if he can supply an original size chain. If possible I don’t know that I want to use an Oring chain, as well as the spacers, Dave Marsden’s book details a bunch of bolts that has to change lengths on the Z1b to avoid rubbing the chain.
That said, as I don’t have any of these bolts yet, I could do the job properly.
1974 Z1A
#7 PostAuthor: ADRIAN H » Tue Aug 11, 2020 7:41 pm
z2.john wrote:Z1B chain is wider due to the O-rings. If you fit this you will need the Z1B front sprocket and the spacer for the rear sprocket
+ 1
z2.john
#8 PostAuthor: z2.john » Wed Aug 12, 2020 6:36 am
+ 1
There are also other considerations with brackets and bolt lengths if using O-ring as attached
191.pdf
(831.95 KiB) Downloaded 161 times
148.pdf
(871.81 KiB) Downloaded 154 times
MrDavo
#9 PostAuthor: MrDavo » Thu Aug 13, 2020 8:17 pm
Thanks for the pdf files, good info there.
All the chain options I’ve found, endless or linked, involve an O ring chain. As the motor has only just gone in, it looks like a good time to order a Z1B sprocket, source the spacer for the rear sprocket, and using my bench grinder, shave 4mm off the bottom engine plate captive nut and its bolt. Anything else I need to know?
I’m fitting the chain oiler because I can, do people still put oil in them?
1974 Z1A
taylor88
#10 PostAuthor: taylor88 » Thu Aug 13, 2020 8:45 pm
Hi Mrdavo
In my mind are you rebuilding an original Z1A? If so why put a Z1B chain on It? Especially as you are fitting the chain oiler. To me it seems a bit strange to fit an o ring chain with a chain oiler
Just my opinion, I hope the rebuild is going well!
Gtb
GTB
MrDavo
#11 PostAuthor: MrDavo » Thu Aug 13, 2020 8:49 pm
My main problem is finding the original chain. Every one I’ve see so far has ‘O Ring’ on the box, even when listed for the Z1 or Z1A. If you can point me at an original one, I’ll use it.
1974 Z1A
z2.john
#12 PostAuthor: z2.john » Fri Aug 14, 2020 6:45 am
MrDavo wrote:I’m fitting the chain oiler because I can, do people still put oil in them?
If you fit the tank with no oil, make sure you do not fit the oil pump drive pin on the gearbox output shaft (assuming you are fitting the oil pump for show)
#13 PostAuthor: Philippe » Fri Aug 14, 2020 11:14 am
Hi MrDavo
ask Willem from Classic Kawasaki Parts. Look at this :Ketting Tsubaki HSL 630; 92 schakels Z1 met klinkschakel en clipschakel géén O ring ketting
€ 25,00
His shop is situated in Holland but he understands English so give it a go!
MrDavo
#14 PostAuthor: MrDavo » Fri Aug 14, 2020 11:33 am
Thanks Philippe - I thought 'O no, it says 'O Ring' so I used Google translate from Dutch to English:
Chain Tsubaki HSL 630; 92 links Z1 with rivet link and clip link, no O ring chain
yes that's the one I need, and I can rivet the chain on the bench, before I buy a gearbox sprocket and sort out some bushes for the swinging arm. Result!
Sorry to be a pain but please can you give me a link to the shop?, I tried Google but couldn't find it.
1974 Z1A
#15 PostAuthor: ADRIAN H » Sat Aug 15, 2020 9:43 am
MrDavo wrote:Thanks Philippe - I thought 'O no, it says 'O Ring' so I used Google translate from Dutch to English:
Good luck,
Link - https://www.classickawaparts.nl/
Users browsing this forum: No registered users and 91 guests
