Does anyone know if a Z750B twin spoked /disc rear wheel hub and the z1000A1 spoked /disc hub are the same?
Think that the sprocket carrier maybe different but wondered about the hub itself
Its the one with the pressed steel ring on the disc side!
Z1000A1 Rear hub question
- thebuelligan
- thebuelligan
Re: Z1000A1 Rear hub question
To answer my own question yes! 750B and 1000 A1 rear wheel hubs carriers spacers are identical!
Re: Z1000A1 Rear hub questioni
Strange as the Hubs have Different part numbers.
Z750 - 42005 - 048
Z1000 - 42005 - 053
Z750 - 42005 - 048
Z1000 - 42005 - 053
- thebuelligan
Have both side by side and all measurements are identical
Tried both carriers in both hubs and all fit perfectly
Result there then. Pleased for you. Does seem odd they have different part numbers.
yep they are identical
- thebuelligan
flateddie wrote:yep they are identical
