ELR 1100 FOOTREST/EXHAUST HANGER QUERY
dave cullen
#1 PostAuthor: dave cullen » Wed Aug 19, 2020 11:29 am
Does anyone know what the bolt nearest the brake pedal secures as per this pic of a standard bike, i found a schematic which shows the original silencer having two mounting holes on its bracket, but it didn't show two sets of bolts securing it.
My ELR with a four into one is missing the forward bolt so I am assuming it is a second securing bolt for the silencer?
Dave
https://images.cmsnl.com/img/partslists ... b_3927.gif
Z900A4 Z1000A1
Re: ELR 1100 FOOTREST/EXHAUST HANGER QUERY
#2 PostAuthor: z1bman » Wed Aug 19, 2020 12:13 pm
if you look at the part no's it lists 4 of all the mounting parts
dave cullen
#3 PostAuthor: dave cullen » Wed Aug 19, 2020 12:53 pm
z1bman wrote:if you look at the part no's it lists 4 of all the mounting parts
Thanks I never looked at that, so the 1100 has two mounting bolts but the 1000 only has one it appears.
my dilemma is I am trying to get a replacement exhaust for the 1100 and the company don't do an exhaust hanger specifically for it, just the 1000R, and I am worried it won't fit at the hanger end!
dave
Z900A4 Z1000A1
Julian_Boolean
#4 PostAuthor: Julian_Boolean » Wed Aug 19, 2020 2:58 pm
Bolt positions do look slightly different to the 1000J/R/1100B1/B2 bracket, you could buy a J bracket and paint it black and fit it, they're pretty common and someone on here will probably have one, I gave a pair to RobW as I had no use for them (he's using them btw)
dave cullen
#5 PostAuthor: dave cullen » Wed Aug 19, 2020 4:18 pm
Julian_Boolean wrote:Bolt positions do look slightly different to the 1000J/R/1100B1/B2 bracket, you could buy a J bracket and paint it black and fit it, they're pretty common and someone on here will probably have one, I gave a pair to RobW as I had no use for them (he's using them btw)
Thanks Julian
Ive confirmed the company do a J bracket so just going to go for that, hopefully it will be close enough, will post result.
Dave
Z900A4 Z1000A1
dave cullen
#6 PostAuthor: dave cullen » Sun Aug 30, 2020 8:27 pm
The J bracket is a perfect fit for the Delkevic Z1100R system
Dave
Z900A4 Z1000A1
Users browsing this forum: No registered users and 118 guests
