Coils
Oggers
Coils
#1 PostAuthor: Oggers » Fri Aug 21, 2020 8:32 am
Chaps
On the z650 I have Accel coils- yellow cylindrical things. They each have the two connectors for the plug leads and two wires for the points and something else - I forget what.....They also have what seems to be an earth - a small black wire - which connects directly to the frame via the coil mounting bolt.
Out of curiosity, is my assumption that this small balck wire an earth correct, and why is it needed? I thought coils earthed through the points?
1946 Ariel VB600, 1966 Triumph Bonneville, 1975 400/4, 1979 Z650
lude
Re: Coils
#2 PostAuthor: lude » Fri Aug 21, 2020 9:47 am
Some sort of earthing suppression?
Wiring diag says earthing is through points for primary coil, secondary coil earthing through the engine via sparkplug.
Users browsing this forum: Bing [Bot] and 78 guests
