Metal bodied oil seals
After trying to fit the 3 metal bodied oil seals (see pic) to the transmission covers with finger pressure, and then tapping them with a wooden drift, unsuccessfully, I discovered they're quite a tight fit. Can they be pressed in using the old threaded rod/washers/nuts trick or is heating the cases the way to go, or a combination of the two? Slightly worried that the cases will get damaged with too much pressure as they look a bit fragile.
Z1-B, 360bhp ZX1000NGF
Re: Metal bodied oil seals
just tap them in with a hammer as long as use tap them in square they will be fine
Users browsing this forum: zed9 and 33 guests
