Link or continuous drive chain?
steve452
#1 PostAuthor: steve452 » Sat May 16, 2020 9:32 am
On my Z1-B rebuild I was wondering whether I should stick with buying a continuous (non-link) drive chain or go with a linked chain. I assume modern linked chains are far more robust and technically advanced than the ones we had in the 70's. It's just that I'd like to install the swingarm and rear shocks but as the engine build will take place last I can't if I go with continuous. Anyone have any opinions one way or another? The bike will be a bog standard April 1975 registered new UK model so no increase in power over original.
Z1-B, 360bhp ZX1000NGF
Re: Link or continuous drive chain?
#2 PostAuthor: zed1015 » Sat May 16, 2020 9:41 am
Nothing wrong with a split link if fitted correctly or you can fit a "soft" rivet link .
I use both with no issues.
steve452
#3 PostAuthor: steve452 » Sat May 16, 2020 10:58 am
Many thanks for the advice. I'll go the split option (one or other) and fit the swingarm. Stay safe.
John0622
#4 PostAuthor: John0622 » Thu Aug 27, 2020 7:18 pm
I only ever saw a series of photos of one bike, a Z900 which had a duplex chain fitted as its final drive. The write up said he had never had to adjust it. Never seen one since.
#5 PostAuthor: chrisNI » Sun Aug 30, 2020 8:02 pm
John0622 wrote:I only ever saw a series of photos of one bike, a Z900 which had a duplex chain fitted as its final drive. The write up said he had never had to adjust it. Never seen one since.
My brothers’s Z1B has a duplex chain it was on it when we got it and he never took it off - I’ll get him to take a pic.
bogtrotter
#6 PostAuthor: bogtrotter » Sun Aug 30, 2020 8:13 pm
Yes got a duplex chain on the well used Z1b on the new members mag. Not really adjusted it but maybe I’m being slack! Never seen another one
John0622
#7 PostAuthor: John0622 » Tue Sep 01, 2020 7:27 pm
I like that! A lot.
Where on earth do you get them from, along with the sprockets.
#8 PostAuthor: chrisNI » Tue Sep 01, 2020 9:49 pm
John0622 wrote:I like that! A lot.
When Z1s first came out they were supposed to be too powerful for the chains that's also why early models had oil tanks. I guess this was a period solution :shock: Don't know who made them.
#9 PostAuthor: Pigford » Wed Sep 02, 2020 6:35 am
Be interesting to see what size/pitch chain links are - the std 630 is heavy enuff :??
#10 PostAuthor: zed1015 » Wed Sep 02, 2020 6:45 am
You can still buy duplex and triplex roller chain for primary drives etc but those kits for bike final drives were a 70's gimic and no one makes them now.
