Handlebar cable ties
MrDavo
#1 PostAuthor: MrDavo » Sat Aug 29, 2020 10:22 am
I bought a set of 4 original cable ties for the handlebar wiring, because they're the ones you see. The rest can be B & Q's finest as far as I'm concerned.
http://www.z-power.co.uk/handle-bar-cable-tie-set-4
My question is, before I put them on, are they single use only, or will they release once I've put them on?
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
Charlie
Re: Handlebar cable ties
#2 PostAuthor: Charlie » Sat Aug 29, 2020 11:39 am
You can fit and release them as much as you like. They do not lock in place, in fact unless you loop the tail and put it back under the loop, they slip and work loose anyway
Users browsing this forum: marmck and 32 guests
