Z1-B Rotor bolt and washer
Can anyone confirm that these are the rotor bolt and washer (114G0-840 & 92022-218). I'm fairly sure the washer is correct as it fits perfectly in the recess at the front of the rotor. Its dimensions are 23.46 OD x 8.51 ID x 4.12mm thick. The bolt is M8 x 46mm with a 1.25 thread pitch. The threaded part alone is c24mm. The reason I ask is that it is a very tight fit into the crankshaft and I'm loathe to tap out the crank thread if I've got the wrong pitch. I know the bolt came off my bike because you can just see the original dab of yellow paint on the RHS of the head.
Z1-B, 360bhp ZX1000NGF
Re: Z1-B Rotor bolt and washer
That doesn’t look Right
Bolt - 8x71mm with a raised section.
https://www.ebay.co.uk/p/1811796796?iid=223153505923
The bolt should be M8 x 40mm long (the clue is in the part number 114G0840)
Pitch for 114 M8 bolts is 1.25mm
Many thanks John. I'll order one from Cradley Heath. Adrian, I think you misheard as I'm on the other end of the crank. Thanks for replying anyway.
steve452 wrote:Many thanks John. I'll order one from Cradley Heath. Adrian, I think you misheard as I'm on the other end of the crank. Thanks for replying anyway.
Ooops - at least you're sorted now.
Users browsing this forum: No registered users and 105 guests
