Wanted Harris exhaust , can be perfect or scrap condition ,
Regards
Stempy
Harris Exhaust
Re: Harris Exhaust
Hi Stempy,
Are you still after a Harris set of pipes?
Cheers, Mike
Cheers, Mike
Re: Harris Exhaust
This came off my ST which I've tarted up. The downpipes were wrapped in that awful cloth tape so a few are pitted but pretty solid and no holes. For some reason, the header clamps are welded to the pipes but still my Gpz1100 B1 with no problems. It's got a track baffle but I've wrapped to reduce the noise slightly and tucked the offending "not for road use" to the back. I've got a bracket to attach to the two nuts located in a channel but you'll probably want to make one yourself outa stainless or steel sheet.
I was gonna keep it, hence the tart up, but gonna find an original set of pipes for the B1. How does £200 incl postage in the UK sound?
Re: Harris Exhaust
Got a scrap one that fitted a gpz1100b if you want it...
Olly
Olly
Lemmy
Lemmy
Users browsing this forum: MikeP and 40 guests
