I could lend you my front sprocket holder, but it locates in holes normally in the sprocket & I see from your photos that your sprocket doesn't appear to have those holes.
Keep the good work up though, looking forward to seeing it finished
Loverly to see another Z1 returning to life & you don't look to be that far away from me either, (Stockport) !
MrDavo wrote:A trail build of one of the calipers, with new pads was too tight to fit on the disc on the side for the extra disc. A bit of head scratching made me realise I could get a bit more of a gap if I removed the paint from the mounting face for the inboard pad as the paint was quite thick. I also had to get paint out of the sliding bushes as they were tight. The calipers now fit over the discs, but only just.
Mounted on the bike, the wheel turns but they feel a little draggy. I don't see how I can possibly get more clearance, the pistons are pushed right back and the inner pad mounts now are paint free, I can only hope they will be free once they have worn in a little, but don't turn the discs blue first!
Andrew_s wrote:MrDavo wrote:A trail build of one of the calipers, with new pads was too tight to fit on the disc on the side for the extra disc. A bit of head scratching made me realise I could get a bit more of a gap if I removed the paint from the mounting face for the inboard pad as the paint was quite thick. I also had to get paint out of the sliding bushes as they were tight. The calipers now fit over the discs, but only just.
Hi Dave,
Just a thought, but have you checked the depth of the discs - the twin set-up on the Z900 uses 7mm discs (the single set-up is 5mm), I'm not sure if this is the same for the Z1 (someone advise I'm sure), but it could be the PO bought oversized discs in error when he went for drilled discs?
Cheers, Andrew
Users browsing this forum: No registered users and 89 guests
