Airbox wanted
popsA1
Airbox wanted
#1 PostAuthor: popsA1 » Fri Nov 13, 2020 10:43 pm
I’m in need of an airbox to fit CV carbs to my Unitrak1100. Any airbox from a from a CV carb’d Z or GPz. Would consider a 750, 1000 or 1100. Any condition as I might have to do some work to make it fit.
Thanks,
Paul
A2 1979-80. A1 1980-now
walshyco
Re: Airbox wanted
#2 PostAuthor: walshyco » Mon Nov 16, 2020 11:38 am
Hi I have an air box from a Z1000 ltd 1980 with CV carbs, if any use.
popsA1
Re: Airbox wanted
#3 PostAuthor: popsA1 » Mon Nov 16, 2020 7:41 pm
Hi, quite possibly. Can you take some pics of it and measure the front to back distance of the base please.
Re: Airbox wanted
#4 PostAuthor: paul doran » Mon Nov 16, 2020 9:14 pm
Z1000j airbox will fit straight in
walshyco
Re: Airbox wanted
#5 PostAuthor: walshyco » Tue Nov 17, 2020 9:59 am
Here are a few pictures, it’s 150 mm the base from front to back, the lid is missing and the rubbers are solid, if it’s any use you can have it, just cover the postage.
popsA1
Re: Airbox wanted
#6 PostAuthor: popsA1 » Tue Nov 17, 2020 11:57 am
I think that will fit. I’d like to give it a go. Let me know the cost. In the meantime I’ll PM you my details.
Re: Airbox wanted
#7 PostAuthor: paul doran » Tue Nov 17, 2020 2:31 pm
It will fit straight in its the same as a J
I have used one on an unitrack with no issues
popsA1
Re: Airbox wanted
#8 PostAuthor: popsA1 » Tue Nov 17, 2020 5:52 pm
Thanks Paul. Walshyco’s looks like a J type box. Apart from the anti-pollution mods, I think the same pattern box was fitted to all the CV carb’d models.
