Backwards bolt?
Mark whiten
Re: Backwards bolt?
#16 PostAuthor: Mark whiten » Tue Nov 24, 2020 9:11 pm
For future reference , easy outs are very good . You drill a pilot hole and screw the easy out in which has a left hand spiral and this unscrews the broken off screw or bolt . Small good quality set less than a tenner
Blackseven
Re: Backwards bolt?
#17 PostAuthor: Blackseven » Tue Nov 24, 2020 9:35 pm
I have always found cheap easy outs can snap all to easily and leave a piece of hardened steel inside the sheared bolt. The methods outlined earlier in this post are much better options IMHO.
Mr Bump
Re: Backwards bolt?
#18 PostAuthor: Mr Bump » Tue Nov 24, 2020 9:36 pm
Blackseven wrote:I have always found cheap easy outs can snap all to easily and leave a piece of hardened steel inside the sheared bolt. The methods outlined earlier in this post are much better options IMHO.
+1.
Lemmy
Re: Backwards bolt?
#19 PostAuthor: chrisNI » Wed Nov 25, 2020 2:01 pm
+1.
+2
Re: Backwards bolt?
#20 PostAuthor: warren3200gt » Wed Nov 25, 2020 3:51 pm
Easy outs = devils spawn. :nik
Re: Backwards bolt?
#21 PostAuthor: kev edwards » Wed Nov 25, 2020 4:44 pm
Well done that man, a little more advice don't buy your kitchen roll at M&S, you can get much cheaper anywhere else. :)
