Rejuvenating shrunken carb rubbers
Mr Bump
#1 PostAuthor: Mr Bump » Thu Dec 03, 2020 6:30 pm
Evening,
Ive done a search on here and other sites, and not really come up with a definitive answer:
Is there a reliable way of bringing Z carb 'rubbers' (I expect they're actually some sort of plastic) back to life and swelling them up a bit? And will they stay like it or harden up again?
I ask because Ive got a set of 'rubbers' that fit between a 750 unitrack air box and carbs. They don't clamp into the airbox like earlier bikes, but sort of push in and rely on the springyness of the material to form a seal.
Mine have gone hard and shrunk a bit, so they no longer seal on the airbox and let unfiltered air in, you can hear it hissing. I should just buy new ones (if available) but I might want to replace the bs34's with something a bit bigger using pod filters (the bike is an 1100) once Ive run it in, so I don't want to shell out for new parts that I might only use for 500 miles or so.
Any advice?
Thanks, Olly
Lemmy
Re: Rejuvenating shrunken carb rubbers
#2 PostAuthor: warren3200gt » Thu Dec 03, 2020 7:35 pm
In a word no. Any soak or heat treatment will be short lived at best.
Gus
#3 PostAuthor: Gus » Fri Dec 04, 2020 9:33 am
I've heard soaking them in clutch/brake fluid will soften them up
Not tried it myself.
Gus
"Set the GRINDER on it"
Stugill
#4 PostAuthor: Stugill » Fri Dec 04, 2020 12:25 pm
In my opinion buy new ones, the money you might be irritated at losing? will be more than offset by the: lack of stress, annoyance and bruised knuckles fitting the old items.
Stu
#5 PostAuthor: Philippe » Fri Dec 04, 2020 3:53 pm
Hi Olly
Stu is right! Buy new ones.
MrDavo
#6 PostAuthor: MrDavo » Fri Dec 04, 2020 4:41 pm
When I restored my CL450 barn find, I found out that genuine NOS inlet rubbers cost an arm and a leg via CMS, and the ones I had were hard as rock after decades of unuse.
A friend from another forum tried soaking them in a special brew (no, not Carlsberg) for a few days which did make them softer, but once I got the bike running it was plagued by runaway tickover and carburation trouble in general.
In the end I had to bite the bullet and sell my soul for a new set, the originals are in a box in the garage somewhere.
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
Mr Bump
#7 PostAuthor: Mr Bump » Sun Dec 06, 2020 11:16 am
Ideal. Thanks for your help.
I suspected that might be the case. I'll have to look up prices.
Or be tight as a duck's arse and temporarily silicone them in until I know if I'm going anywhere with different carbs!
Olly
Lemmy
moizeau
#8 PostAuthor: moizeau » Mon Dec 07, 2020 9:05 am
Mr Bump
#9 PostAuthor: Mr Bump » Tue Dec 08, 2020 9:50 pm
moizeau wrote:I got mine for the ST from here
https://www.ebay.com/str/getor-shop?_bk ... ser&_pgn=2
Ideal. Thanks.
Olly
Lemmy
