J, R, GPZ, unitrac GPZ550 seat lock
Gus
#1 PostAuthor: Gus » Tue Dec 29, 2020 10:48 am
Morning Gents
I'm after the above if any kind souls have some for sale?
Z1000J 1 2 3, GPZ1100 B1 B2 A1 A2, 1000R 1 2, 1100R GPZ550(ZX550) A1 A2 A3 seat locks.
Cheers Amigos
Gus
"Set the GRINDER on it"
Re: J, R, GPZ, unitrac GPZ550 seat lock
#2 PostAuthor: Al » Tue Dec 29, 2020 1:33 pm
I expect you have seen all the offerings on ebay but in case youre search didnt find this.
Bit spendy and no key but may be of some interest!
https://www.ebay.co.uk/itm/1984-KAWASAK ... SwOA9f1sXQ
#3 PostAuthor: Al » Tue Dec 29, 2020 1:34 pm
#4 PostAuthor: Philippe » Tue Dec 29, 2020 4:41 pm
Hi Gus
can you do something with this link?
https://www.bike-teile.de/index.php?sei ... id=1628386
It's in Germany, I know, but most of them understand English and are very correct! But as mister Fawlty used to say: " don't mention the war". :D
Gus
#5 PostAuthor: Gus » Tue Dec 29, 2020 4:59 pm
Thank you Al and Phillipe.
Ideally I need more then one so it could get expensive. I might see if John Browse has anything cheaper and go from there.
Just threw it out there in case one of our noble members had a spare.
Thanks.
Gus
tlc
#6 PostAuthor: tlc » Tue Dec 29, 2020 5:37 pm
I bought one recently in place of pension investments :shock:
Gus
#7 PostAuthor: Gus » Tue Dec 29, 2020 7:53 pm
tlc wrote:I bought one recently in place of pension investments :shock:
:rir :rir :rir
Yes I need to keep both arms and legs at the moment to finish it.
Gus
MikeP
#8 PostAuthor: MikeP » Wed Dec 30, 2020 7:30 am
I've definitely got 2 helmet locks but think I sold the last of my seat locks a couple of weeks ago. I'll go and have a look . . . .
Tomforde make a race seat lock, but might cost an arm and leg:
https://www.ebay.de/itm/333608026980
MikeP
#9 PostAuthor: MikeP » Wed Dec 30, 2020 9:14 am
Sorry only two helmet locks :sad
popsA1
#10 PostAuthor: popsA1 » Wed Dec 30, 2020 9:18 am
I’ve been looking for a seat lock for ages with no luck. I don’t really want to buy a complete set just for the seat lock.
If anyone finds one at the bottom of that bucket we’ve all got full of manky m6 and m8 bolts, if Gus doesn’t want it, I’ll have it.
In the meantime, I wonder if I could make something up similar to the Tomforde race lock. Wouldn’t look as nice but might serve the purpose.
A2 1979-80. A1 1980-now
#11 PostAuthor: Al » Wed Dec 30, 2020 2:44 pm
After going to Cadwell Park and discovering i had left my seat lock key at home (couldnt get seat off to connect battery) i deleted the lock mechanism and put a 6mm nut and bolt through the hole to attach the seat. Later revised to a welded 6mm nut and quick release wing headed bolt for simplicity. Not elegant but practical in the short term.
Gus
#12 PostAuthor: Gus » Wed Dec 30, 2020 3:04 pm
Ditto Pops and also as Al says I just want a means to secure it not necessarily a costly original.
Cheer
Gus
#13 PostAuthor: Al » Wed Dec 30, 2020 4:09 pm
Not pretty but does what i need.
Gus
#14 PostAuthor: Gus » Wed Dec 30, 2020 4:16 pm
:nod :nod :nod
Gus
popsA1
#15 PostAuthor: popsA1 » Thu Dec 31, 2020 4:53 pm
Here’s my first attempt at a seat lock. I got the vertical M6 screw hole in the wrong place. I suspect the bracket on my frame is just a wee bit, slightly bent.
So here’s the second attempt with a few adjustments.
Having printed it in ABS it feels quite sturdy. I was toying with the idea of having a spring loaded pin like Tomforde’s but after seeing Al’s wing nut mod, I just might stick with the nylock nut.
