Hi all,
I have a new loom for the mk2 and it has the plug set up for a Uk /EU right hand switch, mine is a US style, does anyone supply repo Z1000 switches that will just plug in
Gavin
Z1000 right switch cluster
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: Z1000 right switch cluster
you can buy the block connectors from bikers toolbox
https://www.bikerstoolbox.co.uk/acatalo ... ctors.html
Cheers for the info, but my switch being from the USA doesn’t have the lights on and off switch therefore no wires to put into a plug
Z1000 MK2
Z1300 DFI
Z1300 DFI
if its not a us spec harness you can use the european switches from z power https://www.z-power.co.uk/switch-gear-s ... -z900-pair
- 8 Valve Mark
pretty sure that I'll have a spare uk/euro switch Gavin, I'll check later n let you know. m
Users browsing this forum: No registered users and 89 guests
