Z1 Choke Lever and rubber tip
Hi
I’m looking without much success for a choke lever rubber tip , or even better a complete lever .
1973 Z1 .
Thanks .
1973 Z1 .
Thanks .
- warren3200gt
Re: Z1 Choke Lever and rubber tip
Recent discussion on faceache.
https://m.facebook.com/groups/158916233 ... &__tn__=-R
PUM 488 June 2023
Get hold of Jonathon Stobbs on Facebook,
Z1 owners emporium..
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
Does your bike have ‘CHOKE’ and an arrow, painted in red fill, on the choke lever quadrant?
Mine has, and according to John Brookes’ book used only a short cap on the lever. More by accident than design, the short Yamaha tip I used (see the posts linked to) is about right, I don’t need the long plastic cap with the kink.
As your bike is earlier than mine, it may be the same.
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
I should have some of these early type available soon just experimenting with the 3D printer and a more rubber type material
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
Here's my early type choke assembly, with the writing on the quadrant. As far as I can find out, these didn't have the longer plastic tab with the kink and the white writing on.
The rubber tab fitted is the Yamaha part, as linked to in the Facebook post above.
1974 Z1A
Mr Davo
Yes you’re correct it’s just A tip , the dog legged plastic version with the relief was on later models .
Thank you for the fb link I’ll try that route or as you’ve done go for one pretty much near perfect
bedlow 1
Those look great .
Please let me know when you’ve perfected it
Well done .
Those look great .
Well done .
yes those look impressive, fantastic the technology
As a follow up Item 1 is a Z1B replica made on 3D printer , item 2 is a genuine z1 tab, item 3 replica Z1 3D printed , and item 4 is the yamaha tab which some owners have fitted
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
- warren3200gt
Has your item 3 got a concave top surface like the Yam one? Dont know if the original Z1 item 2 has a concave top surface? Cant tell from the pic.
PUM 488 June 2023
warren3200gt wrote:Has your item 3 got a concave top surface like the Yam one? Dont know if the original Z1 item 2 has a concave top surface? Cant tell from the pic.
No its identical to the original which was flat that's why i made one up as some owners were fitting the Yam ones which had a different profile.
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
- warren3200gt
Ah ok. They look good to me. Get churning them out and let me know the cost.
PUM 488 June 2023
Number 2 for me please
