Z1000 MK II Regulator/Rectifier
njwmct
#1 PostAuthor: njwmct » Fri Feb 12, 2021 2:18 pm
I've still not got around to changing the 40+ year old Regulator/Rectifier on my Z1000 MKII - part no. 21066-1008
Electrixworld £55 still appear to be out of stock - also it doesn't look to be plug & play.
This one is listed on E-bay:
https://www.ebay.co.uk/itm/VOLTAGE-REGU ... SwLQtf~CSp
Price seems very low £21 - Anyone know if these are any good ?
KWACKERZ1
Re: Z1000 MK II Regulator/Rectifier
#2 PostAuthor: KWACKERZ1 » Fri Feb 12, 2021 4:49 pm
Zpower stock replacements as do M&P.
#3 PostAuthor: z1bman » Fri Feb 12, 2021 5:17 pm
#4 PostAuthor: Ultim8pc » Fri Feb 12, 2021 6:02 pm
z1bman wrote:https://www.z-power.co.uk/regulatorrectifier-z1000z1-r
Expensive and has wrong coloured connector.
KeithZ1R
#5 PostAuthor: KeithZ1R » Sat Feb 13, 2021 7:38 am
It is actually the correct colour for the rectifier and as the wire connections are common for both the white and the green socket the extra cost is just paying somebody to fill in the gaps in your ablities :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#6 PostAuthor: Ultim8pc » Sun Feb 14, 2021 1:16 pm
My bad, I thought it was for the z900...
Adrianbrooksbank
#7 PostAuthor: Adrianbrooksbank » Tue Feb 16, 2021 8:27 pm
Have used combined regulate rectifier from electret,even cheap chinese ones and just put 3 alternator wires usuall yellow or white,if unsure to check wires from alternator and put red or black if using Hodna type and other to earth both on the battery perfect no trouble,used many times especially on Hodnas oops. Hope this helps
needaz1100r
#8 PostAuthor: needaz1100r » Sun Feb 21, 2021 12:09 pm
Adrianbrooksbank wrote:Have used combined regulate rectifier from electret,even cheap chinese ones and just put 3 alternator wires usuall yellow or white,if unsure to check wires from alternator and put red or black if using Hodna type and other to earth both on the battery perfect no trouble,used many times especially on Hodnas oops. Hope this helps
I do this all the time, CX500, super wet dream or similar Shindengen SH775, never fail, always give good charging. But don't tell anyone as the prices are creeping up....
Mark.
needaz1100r
#9 PostAuthor: needaz1100r » Sun Feb 21, 2021 12:17 pm
Or SH232.
Mark.
rickm
#10 PostAuthor: rickm » Sun Feb 21, 2021 2:01 pm
Would these also work on a Kawa Triple to replace the two separate items ?
H2B GPZ900R
needaz1100r
#11 PostAuthor: needaz1100r » Sun Feb 21, 2021 3:47 pm
rickm wrote:Would these also work on a Kawa Triple to replace the two separate items ?
Do you mean the SH232 that I mentioned? If so, then yes.
Mark.
rickm
#12 PostAuthor: rickm » Mon Feb 22, 2021 9:31 am
Thanks Needaz.
I was thinking about either/both items.
I guess there must be others that would also work as many will be made to perform a similar function?
H2B GPZ900R
njwmct
#13 PostAuthor: njwmct » Wed Feb 24, 2021 1:16 pm
Just an update on this one.
After much investigation I've discovered that most rectifier/regulators that people claim are for the MKII will not actually fit. This is because on the MKII the unit sits behind the LH side panel inside a metal electrical box.
The standard Kawasaki unit is approx 66mm deep with little room to accommodate anything much bigger (you might get away with 70mm but the Electrex World unit for example is 80mm).
David at CY Bike came up trumps in the end as PMC offer a replacement with the same dimensions as the standard unit - part no. 81-4083
#14 PostAuthor: chrisu » Wed Feb 24, 2021 1:19 pm
That’s good to know
On my German z1000h I had to make a small ally plate to get the electrex one to fit
njwmct
#15 PostAuthor: njwmct » Wed Feb 24, 2021 3:48 pm
chrisu wrote:That’s good to know
Do you have a photo showing how you did it?
Users browsing this forum: zapo and 36 guests
