Sprocket carrier spacer Now got one.
I'm looking for a z1b z900 rear sprocket carrier spacer.
The middle one between carrier and hub.
Z-power been out of stock for ages.
Anyone got one they could live without please?
Many thanks
Many thanks
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
Re: Sprocket carrier spacer
are you sure ? .i bought one last week
its just a spacer - easy to make one.
I spaced mine with washers
73 z1, z650c3
ALWAYS LOOK ON THE BRIGHT SIDE OF LIFE
chrisw1 wrote:are you sure ? .i bought one last week
I called them and as you said the zinc is a bit over so new lot on order.
Do you know the dimensions, I may have one.
walshyco wrote:Do you know the dimensions, I may have one.
I'm sorry Sean I don't I'm afraid.
All I can say is the larger dia fits into the sprocket carrier bearing and butts up on the flange.
I don't know The overall length.
Tim
dia 20.1 x 40 x 11 wide
z2.john wrote:walshyco wrote:Do you know the dimensions
I think that's the outer one, it's the inner one between carrier and drum need.
tim.25 wrote:z2.john wrote:walshyco wrote:Do you know the dimensions
Ahhh, sorry...........I assume you want 42036-015. At least Z-power website provides a drawing with dimensions should you have access to a lathe
https://www.z-power.co.uk/rear-wheel-sl ... -1972-1976
I think it’s this one, I can’t find the dimensions for it anywhere, as I said I may have one if you can find the dimensions.
walshyco wrote:https://www.z-power.co.uk/rear-wheel-sleeve-rr-hub-coupling-spacer-z1z900-1972-1976
Yes that's the one, if you click on the link and go to the third picture the dimensions are there.
Sorry mate I thought you were after the spacer between the sprocket and carrier when using an o ring chain but the good news is I have wot you want and it's a genuine part, pm me your address and I'll stick it in the post
73 z1, z650c3
C Martin wrote:Sorry mate I thought you were after the spacer between the sprocket and carrier when using an o ring chain but the good news is I have wot you want and it's a genuine part, pm me your address and I'll stick it in the postIMG_20210313_223146.jpgIMG_20210313_223206.jpg
Brilliant, thank you PM sent.
Users browsing this forum: dazzler, sockpuppet and 16 guests
