Carb overflow pipe routing?
JWO261N
#1 PostAuthor: JWO261N » Sun Mar 14, 2021 5:03 pm
Hi all,
I have the 4 overflow pipes that come out of the bottom of the carbs.
Is there a recommended routing for these, or just common sense maybe?
Wrigers
Re: Carb overflow pipe routing?
#2 PostAuthor: Wrigers » Sun Mar 14, 2021 5:23 pm
Hi mate, you need one of these, obtained from z Power if you haven't got one. It raps around the upper righthand engine mount bolt, and the pipes are fed through it.
JWO261N
#3 PostAuthor: JWO261N » Mon Mar 15, 2021 11:25 am
Wrigers wrote:Hi mate, you need one of these, obtained from z Power if you haven't got one. It raps around the upper righthand engine mount bolt, and the pipes are fed through it.Screenshot_20210314-172015_Gallery.jpg
Excellent thanks.
Then just drop the pipes down clear of the exhausts I guess.
000zeds
#4 PostAuthor: 000zeds » Mon Mar 15, 2021 4:27 pm
Excellent thanks.
Drop the pipes in between rear of engine and swinging arm !
Zeds-R-Us
MrDavo
#5 PostAuthor: MrDavo » Mon Mar 15, 2021 6:18 pm
000zeds wrote:Drop the pies in between rear of engine and swinging arm !
Mmm, pies...... :luv :luv :luv
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
000zeds
#6 PostAuthor: 000zeds » Tue Mar 16, 2021 8:47 am
:oops: :oops: :oops: :) )
Zeds-R-Us
Kwackman
#7 PostAuthor: Kwackman » Tue Mar 16, 2021 9:34 am
This forum is great!
My Z400J has one of those rubber things, but never could figure out how it was attached to the bike.
Until now!
Thanks Wrigers. Another mystery solved.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
Users browsing this forum: Bing [Bot] and 93 guests
