Hi all,
I have the 4 overflow pipes that come out of the bottom of the carbs.
Is there a recommended routing for these, or just common sense maybe?
Carb overflow pipe routing?
Re: Carb overflow pipe routing?
Hi mate, you need one of these, obtained from z Power if you haven't got one. It raps around the upper righthand engine mount bolt, and the pipes are fed through it.
Wrigers wrote:Hi mate, you need one of these, obtained from z Power if you haven't got one. It raps around the upper righthand engine mount bolt, and the pipes are fed through it.Screenshot_20210314-172015_Gallery.jpg
Excellent thanks.
Then just drop the pipes down clear of the exhausts I guess.
JWO261N wrote:Wrigers wrote:Hi mate, you need one of these, obtained from z Power if you haven't got one. It raps around the upper righthand engine mount bolt, and the pipes are fed through it.Screenshot_20210314-172015_Gallery.jpg
Excellent thanks.
Drop the pipes in between rear of engine and swinging arm !
Zeds-R-Us
000zeds wrote:Drop the pies in between rear of engine and swinging arm !
Mmm, pies......
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
MrDavo wrote:000zeds wrote:Drop the pies in between rear of engine and swinging arm !
Mmm, pies......![]()
Zeds-R-Us
This forum is great!
My Z400J has one of those rubber things, but never could figure out how it was attached to the bike.
Until now!
Thanks Wrigers. Another mystery solved.
Until now!
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
1982 Z400J project
ex owner of Z1100R
Users browsing this forum: No registered users and 147 guests
