Hi guys
I have just noticed on No. 4 carb,one of the overflow tubes has cracked inside the chamber where it enters the casting, are these tubes available from anywhere or is it a new chamber required, unfortunately it is off a set of pumper carbs so is slightly different
Gavin
Z1000 float chamber issue
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: Z1000 float chamber issue
clean it up, and solder the crack
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
KeithZ1R wrote:clean it up, and solder the crack
What he said, if they're brass they should solder.
Cheers Keith & Garry,
It was cracked just below the point it enters the aluminium body, had a couple of tries with no success then decided the open the crack up a little and put lots of solder in, then drilled the tube clear of solder,
Jobs a good un it doesn’t leak.
Z1000 MK2
Z1300 DFI
Z1300 DFI
Users browsing this forum: No registered users and 108 guests
