Z1000ST crankcases and crankshaft SCRAPPED
I am having a clear out and have a set of ST cases, with crankshaft and selectors, selector drum etc. Need cleaning, but no damaged threads or broken bits as far as I can see. I download/file.php?mode=view&id=21858would like £40 to clear, collected, I don't fancy packaging and couriering. Numbers as per photo
Re: Z1000ST crankcases and crankshaft
Hi Mick
I don't need an engine but if you have a long rear mudguard , a toolbox or a kickstarter I 'm interested!
Hi Philippe, sorry I do not have any other ST bits, I did have one many years ago and I did have a kickstarter somewhere, if I come across it I will let you know, regards, Mick
Hi mick, I'm interested. Were abouts are you.
i am near Gainsborough, North Lincolnshire
Philippe wrote:Hi Mick
Hi
Long rear mudguard you can get via the club (Jerry) or direct from LPM plastics
Hi Mick
if you find the kick starter, just send a PM please, thanks .
@ chrisu: are you sure it's a long rear mudguard for an ST ? It's not the same as the one for a MK2 or for a Z1R.
But thanks anyway!
But thanks anyway!
But thanks anyway!
Then no probably not
