Well its been a few months since my last update and there's not been a lot of progress, sadly. Life just seems to have got in the way lately and other things have taken priority and the poor old GPz has got pushed down the pecking order
I've tried to keep things ticking over and doing little jobs as and when time allows, but there's not been massive progress of late.
One of the jobs I did manage to complete was to get the brakes fitted, although it wasn't all plain sailing ! I had previously had the brakes totally rebuilt and they'd been sat on a shelf in the garage waiting to be re-united with the bike. The rear went on perfect and I had it fitted & bled within 30 minutes. The front, however, was a different story. To cut a long story short, the m/cyl piston would not return fully after compression, so no fluid was being pumped into the lines. What followed was a few weeks of frustration as I returned the m/cyl to Powerhouse for inspection. They found no problem, sent it back, it was still the same. I sent it back again and again they found no problem. So third time lucky ? Yes, this time the m/cyl piston finally returned fully and I could now bleed the brakes OK. Not sure why there was an issue before, possibly the length of time they sat in my garage caused the seal to swell or age ? Who knows, but it's sorted now and one more job off the list
One job I did have success with was rebuilding the old ignition switch. The lock worked OK, but it had worn so much you could remove the key in the "on" position"
I know I could have bought a pattern lock and possibly had it modified to my key, but all the locks are original and 1 key fits all, so I wanted to retain it if at all possible. I had a couple of other , old ignition locks from other bikes, so used them as a guinea pig to see how to strip them down and what I was faced with. I also thought I might be able to cannibalise them to make a good one for me. Once stripped down, I found the issue was wear on the brass tumblers - over the years, the action of the key being inserted & removed had worn a groove in all of them. Looking at them, I thought maybe I could build them up using a brazing torch & filler rod. What followed was a very lengthy process of brazing up, then filing down 7 tumblers, checking all the time to get the correct height when the key was inserted. Although very time consuming, it was very rewarding to re-assemble the switch and have it not only work, but the key does not pull out in the "on" position - result
A coat of paint on the switch body and a new decal for the lettering completed the job.
You can see the original tumblers at the bottom and the lower edge of the inner cut out is dished - this is the area that needed building back up. Above are the tumblers after brazing. The filler went in places I didn't need ! So it was a lot of filing to get them perfect !
- Tumblers.jpg (26.11 KiB) Viewed 146480 times
But when they all line up when the key is inserted, all that effort is worth it !
- Lock.jpg (16.19 KiB) Viewed 146480 times
The lettering on the cover was just a bit too faded. Unfortunately, the lettering is very slightly raised off of the surface, so despite my best efforts, I couldn't touch it in to my satisfaction and used a decal instead.
- Switch cover.jpg (35.97 KiB) Viewed 146480 times
And here it is, complete and fitted to the bike.
- Ignition Switch.jpg (55.39 KiB) Viewed 146480 times
