13mm Under Bucket Shim Swap Shop. Now Under New Management.
Swirl
Re: 13mm Under Bucket Shim Swap Shop. Now Under New Management.
#31 PostAuthor: Swirl » Wed Sep 13, 2017 7:05 pm
ADRIAN H wrote:
Swirl wrote:Hi who is doing the shim exchange nowadays for the larger Z9 shims thanks Swirl
Jerry - el presidente I believe.
thanks will drop him a line
David Watson
#32 PostAuthor: David Watson » Sat Aug 25, 2018 9:45 am
Hi Ginger Bear.
could you supply me with the details of " Jerry ", as i'm needing to make an exchange of the larger Z1000 over bucket valve shims.
Thanks, Dave
#33 PostAuthor: Ginger Bear » Tue Aug 28, 2018 7:29 pm
Dave, you can PM Jerry, his username is Jerry, but it has been known for him to take a while to respond.
You'll also have to join the club to access the free shim swap scheme.
# 104
RussG
#34 PostAuthor: RussG » Wed Aug 12, 2020 10:31 am
All good stuff, I have some larger shims to swap for a Z1000A1, could you tell me how I contact “Jerry” please? I’m assuming the same process is used as detailed for the smaller ones?
Russ
Z650C2, B1, F1, ZX9R, Z1000A1
#35 PostAuthor: chrisNI » Wed Aug 12, 2020 5:23 pm
RussG wrote:All good stuff, I have some larger shims to swap for a Z1000A1, could you tell me how I contact “Jerry” please? I’m assuming the same process is used as detailed for the smaller ones?
Russ
Jerry’s username on here is “Jerry” as mentioned above so Pm him on here - or call him his details are in the club yearbook/new members handbook
zippy
#36 PostAuthor: zippy » Sat Oct 30, 2021 9:19 pm
Who is doing the shim swaps for the 13mm shims now. Cheers,
KeithZ1R
#37 PostAuthor: KeithZ1R » Sun Oct 31, 2021 10:25 am
Contact club member stephen parr of this forum
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
zippy
#38 PostAuthor: zippy » Sun Oct 31, 2021 1:15 pm
What's his username?
KeithZ1R
#39 PostAuthor: KeithZ1R » Sun Oct 31, 2021 2:16 pm
zippy wrote:What's his username?
stephen parr
Keith
:bop :gom
mistaken.
#40 PostAuthor: chrisu » Sun Oct 31, 2021 2:43 pm
:lol:
Users browsing this forum: Google [Bot] and 75 guests
