ADRIAN H wrote:Swirl wrote:Hi who is doing the shim exchange nowadays for the larger Z9 shims thanks Swirl
Jerry - el presidente I believe.
thanks will drop him a line
RussG wrote:All good stuff, I have some larger shims to swap for a Z1000A1, could you tell me how I contact “Jerry” please? I’m assuming the same process is used as detailed for the smaller ones?
Russ
zippy wrote:What's his username?
