Side panel mounts
1975-S1C
Side panel mounts
#1 PostAuthor: 1975-S1C » Tue Nov 23, 2021 2:44 pm
Afternoon folks,
I have a Z900 but would like to put the slimmer Z1B type side panels on it. Ideally repaint in that scheme too.
My question is if I buy the Z1B brackets that provide the front mounting for the side panel lugs, will they fit my bike ?
And if so, do I need to change anything else to make the panels fit ?
I know I have to change the air box and already have one to fit.
Cheers in advance for any advice.
Paul
kawasaki_man
Re: Side panel mounts
#2 PostAuthor: kawasaki_man » Tue Nov 23, 2021 6:45 pm
1975-S1C wrote:Afternoon folks,
Paul
Hi Paul, my experience was the rear mounting for the Z900 is not exactly in the correct place for the Z1B style side panels. I found that out after welding and painting had been completed on the frame so I have improvised with home made brackets as shown in the picture, with a welded solution sometime in the future. The panels are fine and have now done around 2500 miles without coming off. Photo of right hand side arrangement for reference.
20190923_153443 (3).jpg (179.78 KiB) Viewed 1657 times
#3 PostAuthor: ADRIAN H » Tue Nov 23, 2021 6:51 pm
Rear mounts on both sides are different and you also have the seat lock on the left hand side.
I ended up removing the lugs on the left hand side panel, making new lugs and refitting them.
1975-S1C
#4 PostAuthor: 1975-S1C » Wed Nov 24, 2021 1:16 pm
Cheers guys.
Just wondering though, if I bought the Z1b brackets (rather than make my own) will they fit my Z900 ok and give me the front mounting points for the side panels in the right place ? Thanks
#5 PostAuthor: ADRIAN H » Wed Nov 24, 2021 5:32 pm
1975-S1C wrote:Cheers guys.
Yes, the Z1 - Z1B brackets will fit a Z900.
1975-S1C
#6 PostAuthor: 1975-S1C » Wed Nov 24, 2021 6:06 pm
Splendid. Thanks Adrian
