Ethanol resistant Viton seal replacement for all rubber tipped choke plungers.
Advertise your BIKES and PARTS here
Re: Viton choke plunger seat replacement for Mikuni 8mm and 10mm choke plunger heads. VM slide and BS CV carbs etc. etc
#31 PostAuthor: zed1015 » Tue Oct 19, 2021 11:14 am
Stugill wrote:Rob.
Do you do this for RS34 flatslides?
Stu
Yes! All Mikuni Rubber tipped plungers.
Stugill
#32 PostAuthor: Stugill » Tue Oct 19, 2021 5:30 pm
zed1015 wrote:
Stugill wrote:Rob.
Stu
Cheers Rob.
I'll make contact and then send them to you in the winter months.
Stu
Peteypops23
#33 PostAuthor: Peteypops23 » Fri Oct 29, 2021 2:27 pm
Bloody great service Rob, thank you.
Resealed plungers received back this morning.
You're a star!! :D
#34 PostAuthor: zed1015 » Thu Dec 23, 2021 2:24 pm
Plungers to the rich and famous :) .
Latest batch of refurbed choke plungers and air corrector jets all packed ready for their return trip to the New Zealand workshops of a certain Mr Crosby ( and it ain't Bing :wink: ).
#35 PostAuthor: Bill P » Thu Dec 23, 2021 6:40 pm
Top Job :) Word gets round don't it
rickm
#36 PostAuthor: rickm » Fri Dec 24, 2021 12:30 pm
That's brilliant ! :up
H2B GPZ900R
tightwad
#37 PostAuthor: tightwad » Sat Jan 01, 2022 6:16 pm
eventually got round to fitting some of robs refurbished choke plungers, happy to say it got rid of the off idle stutter, great job, :up didn't think i would get chance this early in the year to try it
thanks ken
Stugill
Re: E10 ethanol fuel resistant Viton choke plunger seal replacement for all Mikuni choke plungers.
#38 PostAuthor: Stugill » Fri Jan 21, 2022 10:22 am
Just got the choke plungers for my RS34's back from Rob, they look brand new and very quick service. Thanks Rob.
Stu
johnA
#39 PostAuthor: johnA » Mon Mar 21, 2022 4:55 pm
Quick shout out for Rob's choke plunger refurb service arrived back today looking like new cheers Rob.
DavidZ1R
#40 PostAuthor: DavidZ1R » Mon Mar 21, 2022 10:04 pm
Yes Rob did a second set for me last week, great job, great service, thanks Rob.
Robw
Re: E10 ethanol fuel resistant Viton choke plunger seal replacement for all rubber tipped choke plungers.
#41 PostAuthor: Robw » Mon Mar 06, 2023 3:02 pm
Hi, would it be possible to send you a set of plungers to get refurbished?
Rob
#42 PostAuthor: zed1015 » Mon Mar 06, 2023 4:30 pm
Robw wrote:Hi, would it be possible to send you a set of plungers to get refurbished?
Rob
Yes!
PM sent.
HowieD
#43 PostAuthor: HowieD » Tue Mar 07, 2023 8:32 pm
Just thought I'd post a pic of my as received back set for Horace.
75hmp
#44 PostAuthor: 75hmp » Sun Apr 02, 2023 4:21 pm
Hi Rob, just received my choke plungers, you've done a cracking job thank you, can't wait to see how the bike runs when it's all back together, once again thanks, Phil.
Charlie
#45 PostAuthor: Charlie » Mon Apr 03, 2023 9:23 am
I just got around to fitting the set of plungers I bought from Rob back in 2020! Time flies
Wow, what a total transformation (Z650). Not only do the chokes work properly now, with no racing, no spitting and a consistent idle ... but its also better on idle off-choke too. I guess they were sucking in air whether lifted or not ?
The bike had actually been off the road anyway, so I am not quite as guilty as it first looks, but I can heartily recommend this service. The carburation was always good on mine (except at cold), now its right on the nose from cold to hot :)
There are what came out...clearly past their best, but the replacements are all shiny and new now
I also took the opportunity to replace the seals in the vac tap and the filler cap which were also goosed.
Newly rezinced choke bar and lifters too.
Return to “For Sale”
