Indicator relay switch - KZ900 A4 LTD 1976
JohnMZ900
#1 PostAuthor: JohnMZ900 » Wed Feb 02, 2022 3:48 pm
Hi there, I’m currently restoring my bike and don’t know whereabouts on the bike the indicator relay switch unit is situated as it didn’t have one when I got it.. any clues please?!
Re: Indicator relay switch - KZ900 A4 LTD 1976
#2 PostAuthor: chrisu » Wed Feb 02, 2022 3:49 pm
not sure about the LTD but the A4 had 2 relays - 1 either side.
1 for the indicators and one for the 4 way flashing
have a look on cmsnl.com for exploded diagrams.
#3 PostAuthor: z1bman » Thu Feb 03, 2022 1:18 pm
if you mean the actual switch to turn them on
Gus
#4 PostAuthor: Gus » Thu Feb 03, 2022 1:56 pm
I would say the round rubber support that holds the flasher relay fits over the end of this tang
Gus
"Set the GRINDER on it"
#5 PostAuthor: z1bman » Thu Feb 03, 2022 4:31 pm
Gus wrote:I would say the round rubber support that holds the flasher relay fits over the end of this tang
Gus
your bang on there gus
#6 PostAuthor: Philippe » Thu Feb 03, 2022 5:11 pm
Hi guys
correct me if I'm wrong please but the KZ900Ltd didn't had the button to illuminate the four indicators at once.
The official name was KZ900B1 Ltd and not KZ900A4 Ltd. I know it's a detail but when searching for parts you need the correct name of the bike.
Gus has pointed out the correct place to mount the relay.
JohnMZ900
#7 PostAuthor: JohnMZ900 » Fri Feb 04, 2022 5:41 pm
Hi there, thanks for all your help on this... I've got a firm answer now, I know where the point is on the frame. John
CAT3
#8 PostAuthor: CAT3 » Sat Feb 05, 2022 12:59 pm
The '76 A4's had two "indicator" relays.
The picture with the circled item on is where the hazard indicator lives & the normal turn indicator relay lives behind the left-hand side panel, just near the seat lock barrel.
Gus
#9 PostAuthor: Gus » Sat Feb 05, 2022 1:39 pm
KZ900A4
KZ900 B1 Ltd
