Standing room only solution.
#1 PostAuthor: zed1015 » Mon Mar 21, 2022 10:19 pm
Rapidly running out of floor space in the shed due to a newly acquired Harrison mill.
Decided to re-jig the place and somehow make room so i can actually get back in there to carry on with work on the current project bikes .
No scope to build out so had to get inventive.
Motorised cable lift cobbled from scrap box section roadwork sign frames, old wheel bearings, home made pulleys and a builders winch works a treat and i now get parking for two bikes in one space.
Just some minor tweaking and a tart up with a coat of paint to finish it off :D
steve452
Re: Standing room only solution.
#2 PostAuthor: steve452 » Mon Mar 21, 2022 10:46 pm
What about the roof? You may be missing a trick there.
Z1-B, 360bhp ZX1000NGF
#3 PostAuthor: zed1015 » Mon Mar 21, 2022 11:26 pm
steve452 wrote:What about the roof? You may be missing a trick there.
Only 3 foot odd at the ridge in the loft.
Tall enough to crawl around and store parts but that's it.
Stuck to permitted development when i built it so only 14 foot x 22 foot internally and 13 foot to the apex which was more than big enough before i filled it up :lol:
z2.john
#4 PostAuthor: z2.john » Tue Mar 22, 2022 7:34 am
Great idea Rob. :idea I have a similar problem. Might have to copy you
By the way, how much WD40 does a guy need :lol:
#5 PostAuthor: zed1015 » Tue Mar 22, 2022 8:37 am
z2.john wrote:By the way, how much WD40 does a guy need :lol:
Don't normally use it but Tesco's had it at £2 ish a tin on clubcard prices so the missus bought a bunch for Valentines.
Not a squeaky door within a 5 mile radius of my house now :lol:
#6 PostAuthor: Bill P » Tue Mar 22, 2022 9:54 am
What a great idea :up
Much better than my quick fix
steve452
#7 PostAuthor: steve452 » Tue Mar 22, 2022 4:33 pm
z2.john wrote:...
The calculation is the same as the number of bikes you need;
NEED = CURRENTLY OWNED + 1
HTH
Mr Bump
#8 PostAuthor: Mr Bump » Wed Mar 23, 2022 1:40 pm
I like that, you've got me thinking. Could use an old tail lift maybe...
Or dig down...
Olly
Lemmy
#9 PostAuthor: zed1015 » Wed Mar 23, 2022 2:39 pm
Mr Bump wrote:I like that, you've got me thinking. Could use an old tail lift maybe...
Or dig down...
Olly
I realised i could maybe use a tail lift but only after i was halfway through building this.
Had a look on Ebay at the time and there was a few around £200 which was tempting but they were all miles away.
Would also have loved to have dug down too but any more than a couple of feet round here and you hit the water table so only good for an indoor pool :lol:
#10 PostAuthor: zed1015 » Wed Mar 23, 2022 6:04 pm
All finished , painted and prettied up.
And this is the mill responsible for the desperate measures which has forced a total re-jig of the shed and several months lack of progress on the project bikes.
To figure out the layout i had to move the lathe and mill around a fair bit to find the best position so i ended up making these machine skates from I beam offcuts and some cheap £50 a set Ebay levelling castors.
They work very well and the machines which weigh around 650 kg each take only as much effort to move as pushing around a full supermarket trolley.
#11 PostAuthor: Bill P » Wed Mar 23, 2022 6:12 pm
Lovely set up you have there :)
Return to “The Bottom Shed”
