z900 swingarm query
Peteypops23
z900 swingarm query
#1 PostAuthor: Peteypops23 » Tue Mar 29, 2022 4:51 pm
Evening all....
I've got the swingarm off for painting etc.
Don't know whether to go for a SWING ARM NEEDLE BEARING KIT or just replace the bushes and sleeves? They've been good enough for the last 45 years or so.
Opinions please :)
Re: z900 swingarm query
#2 PostAuthor: Ultim8pc » Thu Mar 31, 2022 8:36 am
Just use the sleeves. Most of the needle kits I've tried are not very good.
Peteypops23
#3 PostAuthor: Peteypops23 » Fri Apr 01, 2022 1:26 pm
Thanks for that :D
Barnett
#4 PostAuthor: Barnett » Mon Apr 18, 2022 8:35 pm
The bush is a far better engineering solution than needle rollers which experience only a tiny amount of movement at the pivot point.
Mr Bump
#5 PostAuthor: Mr Bump » Fri Apr 22, 2022 9:23 pm
Barnett wrote:The bush is a far better engineering solution than needle rollers which experience only a tiny amount of movement at the pivot point.
...which presumably is why nearly every decent bike after about 1980 has needle rollers.
Lemmy
Barnett
#6 PostAuthor: Barnett » Tue Nov 15, 2022 2:31 pm
No its done because its what the customers want; marketing, sells more bikes.
Users browsing this forum: No registered users and 128 guests
