Ignition barrel problem
moizeau
#1 PostAuthor: moizeau » Wed Jun 22, 2022 3:28 pm
Chaps, The key can be removed irrespective of it's position. I've checked that it can't be operated with a flat blade screwdriver and I don't want to replace it because 1 key fits all 3 locks. Is it as simple as giving it a good spray of lube or does it need stripping?
Re: Ignition barrel problem
#2 PostAuthor: warren3200gt » Wed Jun 22, 2022 6:07 pm
A good lube should sort it. Sounds like the tumblers are not sliding in and out. Happen a lot with ignitions which are stored with the key in place and dust a crap gets inside and gums them up or the the little flap gets bent and the lock is open to the elements.
gray
#3 PostAuthor: gray » Wed Jun 22, 2022 9:00 pm
I thought a zed's keys could be removed from the ignition when the bike was running, so it couldn't fall out when riding. Thought this was a design feature. perhaps its just mine and a few others that do it.
PS when lubricating locks use dry graphite powder- a wet substance eg oil or grease will attract dust and grit.You can buy it in small tubes with a nozzle - mine has lasted 20 years.
gray
moizeau
#4 PostAuthor: moizeau » Thu Jun 23, 2022 5:19 am
Thanks chaps, The flap is deformed so the barrel is open all the time. I'll have a look for the graphite powder, thanks for the tips.
needaz1100r
#5 PostAuthor: needaz1100r » Tue Jun 28, 2022 7:02 pm
gray wrote:I thought a zed's keys could be removed from the ignition when the bike was running, so it couldn't fall out when riding. Thought this was a design feature. perhaps its just mine and a few others that do it.
Soooo....they made it so that the key will come out in the on position, so that you can remove it so that it won't come out, which it would do because it was made so that it could come out??
No wonder some bright spark came up with the idea of making it so that the key didn't come out in the on position, so that you didn't have to take it out to stop it coming out because it couldn't??
Mark.
#6 PostAuthor: warren3200gt » Tue Jun 28, 2022 7:09 pm
:lol: :lol:
Users browsing this forum: Mick J and 52 guests
