Z1000st Rear master cylinder repair kit
Got all the brake parts I need but can't find a seal/repair kit for the rear master if no longer available what are my options?
LTD Project
Re: Z1000st Rear master cylinder repair kit
you can still get a new piston, rubber seals and spring from CMSNL, so I guess z-power should be able to get them too.
KZ1000 B4 under light restoration.
Hi Mrglee
have look at this:
https://www.z-power.co.uk/z1000e1e2-st/ ... r-cylinder
these are original Kawasaki parts.
There's a pattern replacement available too.
have look at this:
Cheers guys but z-power only have kits for the E1 with resivor built into master model mines a e2 which has a separate resivor connected by a short hose nobody seems to have one anymore.
So any suggestions on how to get round this problem would really be appreciated.
Yes I did but they don't have them either from what I understand the master cylinder (43020-1015) was only fitted for a very limited time but have found two places one in America £100 and Australia on eBay for £50 that can supply the two rubber seals.
LTD Project
According to csml the part no for the piston is the same as the z1000 a1 & other models so this should fit
https://www.z-power.co.uk/piston-rear-master-cylinder
Have already been advised this will not fit here's a pic of mine
