Z900A4 Black plugs
Hack
Re: Z900A4 Black plugs
#16 PostAuthor: Hack » Mon Jul 03, 2023 6:31 pm
Hack, the amount of excess / un-necessary fuel you have used over the last 18 years could have bought you a colourtune. Currently around the £40 mark. If you get rich readings at idle speed with the colourtune and cant dial it out by the time you reach 2,000RPM using the air / fuel screws, you likely have worn choke plunger seals assuming everything else is ok; Correct size pilot jets and not worn out, not overly restrictive air filter, standard settings for needle and needle jets etc.
Can i ask what reason for the rebore,... was it because you had very many small vertical grooves in the faces of the bores?
Haha, yes, but checking my insurance mileage declaration I only did 135 miles last year and 120 the year before :eek , so not going have used much extra fuel!
I've owned a colourtune for as long as I can remember but whenever I use it I don't find I can draw any real conclusion - I'll give it another go.
Everything is standard, carbs are good, all jets/needles were replaced and i have double checked they are correct again while the carbs are off this time. Air filter is new, and has been replaced over the years. One thing I did find this time was that the mesh gauze in the air box behind the inlet rubbers was well cruddy, possibly to the point where it would have impacted air flow. The gauze has two layers and the crud was not immediately apparent as it was between the layers. That's now spotless so I'll see if this changes anything.
I'd previously seen the posts regarding choke plunger seals so took mine out and they didn't appear hard or cracked - probably should have them done anyway.
Engine top end was off for other reasons and when measured, the barrels were just inside tolerance. It seemed mad not to put new rings in and when I saw the price for an IMD 1st o/size piston kit wasn't that much dearer than a set of rings I decided to go with that - whether that was a good decision will be apparent soon.
The bores weren't particularly scarred, I've seen worse,why do you ask?
Thanks Andy
Stagman
#17 PostAuthor: Stagman » Mon Jul 03, 2023 9:16 pm
Just out of interest guys, aren't the choke plunger seals controlling air? If so then wouldnt leaking seals make for leaner running?
#18 PostAuthor: Al » Mon Jul 03, 2023 9:19 pm
:D If you find that twiddling the air or fuel screw does not have much effect on the mixture strength showing up on the colourtune, it could be that the idle circuit is being overwhelmed by the choke plunger seals leaking. 3/4 of a turn on mine which are fuel screws, takes it from one extreme to the other.
Reason to ask about the rebore was trying to get an idea of the amount of carbon build up and maybe what type. The dry stuff seems to break off in smaller particles leaving smaller vertical grooves in the bore face when it lodges between bore and piston. The thick black sticky stuff, when it gets blasted off the combustion chamber / piston crown seems to get lodged in the same way but often seems to give fewer, but more visible / detectable / deeper grooves. Its only my opinion based on limited experience but was curious to know the reason for rebore on an engine that is showing up that particular anomaly.
#19 PostAuthor: zed1015 » Tue Jul 04, 2023 7:39 am
Stagman wrote:Just out of interest guys, aren't the choke plunger seals controlling air? If so then wouldnt leaking seals make for leaner running?
No! The choke plungers provide a rich mixture for cold starting.
The seals shut off the fuel supply when the choke is closed.
When the seals are worn and leaking ( which they all are if original ) they cause rich running , sooty plugs, low mpg etc etc.
#20 PostAuthor: warren3200gt » Tue Jul 04, 2023 8:46 am
Screenshot_20230704_094444_Samsung Internet.jpg (83.24 KiB) Viewed 2635 times
Stagman
#21 PostAuthor: Stagman » Thu Jul 06, 2023 5:00 pm
Cool, thanks
Hack
#22 PostAuthor: Hack » Sat Jul 08, 2023 4:37 pm
Just got my choke plungers back from zed1015 with nice new seals.
They look good and excellent turnaround.
#23 PostAuthor: r3sc » Sat Jul 08, 2023 6:04 pm
Rob does a top job!
