Z1 disc grinding
shaggy
Z1 disc grinding
#1 PostAuthor: shaggy » Thu Oct 19, 2023 2:04 pm
Hi am in need of a pair of drilled discs being ground milled have look in the trusted traders section anyone point me in the right direction I can get these done please.
wilsonsjw11
Re: Z1 disc grinding
#2 PostAuthor: wilsonsjw11 » Thu Oct 19, 2023 2:40 pm
You can try Coventry Boring but specify that the surface needs to be as smooth as possible from the grinding process otherwise you will encounter brake chatter from braking at speed.
Regards
Steve
#3 PostAuthor: warren3200gt » Thu Oct 19, 2023 2:55 pm
Thurston engineering in Essex. Proper surface ground not crappy lathe skimmed. I've had several done by them and every one has come back perfect.
shaggy
#4 PostAuthor: shaggy » Thu Oct 19, 2023 3:50 pm
Hi mate and these were z1 discs
#5 PostAuthor: warren3200gt » Thu Oct 19, 2023 3:55 pm
Some 7mm & 5mm Z650 discs and some A4 7mm & 5mm discs.
shaggy
#6 PostAuthor: shaggy » Mon Oct 30, 2023 9:49 am
Have sent off to Thurston engineering will post again when I get the discs back
#7 PostAuthor: warren3200gt » Mon Oct 30, 2023 4:49 pm
What did they quote you Shaggy? It's been a while since I had some done.
wilsonsjw11
#8 PostAuthor: wilsonsjw11 » Sat Nov 04, 2023 5:45 am
I will be interested to see a photo of the finished surface.
Regards
Steve
#9 PostAuthor: warren3200gt » Sat Nov 04, 2023 6:32 am
After 3k miles.
Users browsing this forum: No registered users and 90 guests
