Hydraulic clutch conversion ?
phil1r
#1 PostAuthor: phil1r » Mon Jan 08, 2024 11:32 pm
Hi Folks, has anyone ever converted a standard clutch to the above. if so does a kit exist, or parts like a slave cylinder off another another bike. I know a dedicated one will be impossible to find, but willing to do some converting. Its to go on a Z1R . Thanks in advance.
Re: Hydraulic clutch conversion ?
#2 PostAuthor: zed1015 » Mon Jan 08, 2024 11:48 pm
I've done loads using ZXR type slave cylinders on outrigger plates etc but if you want an invisible conversion then there a chap called Falk Stumm in Germany who makes one that fits out of sight in the stock sprocket cover.
#3 PostAuthor: Z1streetfighter71 » Tue Jan 09, 2024 8:18 am
Like Zed said there i used an out riggger plate and a gsf1200 slave as i had one on my Bandit 12 i bought a Nissin master from Webike. Getting the distance in spacing and the length of the push rod right was a chore but works a charm now.
#4 PostAuthor: chrisu » Tue Jan 09, 2024 9:23 am
agree with the falk stumm recommendation. I use the same. Also ZRX Master Cylinders look neat and work well.
KeithZ1R
#5 PostAuthor: KeithZ1R » Wed Jan 10, 2024 9:28 am
Talk to Ralph @ Bikerstoolbox he might make you one :up
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Grog
#6 PostAuthor: Grog » Wed Jan 10, 2024 1:01 pm
Hi Phil1r
Are you set on a hydraulic conversion or are you just looking to make the clutch easier to use? I asked a similar question earlier in the year (also about a Z1R) and the easiest recommendation was an easy-clutch kit. I've attached my thread - there's also another thread from chrisu linked to that one. I've not fitted one yet (webike were out of stock at the time) but it's one the list of things to do once the weather improves a bit.
viewtopic.php?f=4&t=50633&p=413430&hilit=easy+clutch#p413430
TTFN Grog
1979 Z1R (mostly - it's been fiddled with a bit)
1977 Z650B1 - I'll get round to putting it back together one day...
phil1r
#7 PostAuthor: phil1r » Thu Jan 11, 2024 10:29 pm
Hi Grog, thanks for that, I will look at the other option as well. I would like to make it much lighter. If possible,
Also trying to keep the bike looking correct.
compo z1r
#8 PostAuthor: compo z1r » Fri Jan 12, 2024 12:18 am
phil1r wrote:Hi Grog, thanks for that, I will look at the other option as well. I would like to make it much lighter. If possible,
go one better fit a electric shift drum :D just a button on handlebar :D
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
#9 PostAuthor: ADRIAN H » Sat Jan 13, 2024 6:15 pm
ZX12-R slave and master cylinder on home made cover plate.
HowieD
#10 PostAuthor: HowieD » Mon Jan 15, 2024 3:50 pm
Z1streetfighter71 wrote:Like Zed said there i used an out riggger plate and a gsf1200 slave as i had one on my Bandit 12 i bought a Nissin master from Webike. Getting the distance in spacing and the length of the push rod right was a chore but works a charm now.IMG_2718.jpg
I have a very similar Plate made by Spectra Engineering but using an Oberon Slave Cylinder
#11 PostAuthor: chrisu » Mon Jan 15, 2024 5:34 pm
then the eazyclutch option would be your best choice I think
