Gpz1100 a2 engine breaking
Gpz1100 a2 head,all fins and studs in good condition.it will need a repair at one of the cam bolt threads as it ls damaged please see photo.all parts of the engine available.£200.00 ph 07443589994 if interested.
neilbarrett
- ZedHead
Re: Gpz1100 a2 engine breaking
Were abouts you based?
N.ireland
- Z1streetfighter71
- ZedHead
What number range is the engine if you still have it James.
Still have crank cases,if any good to you.
- Z1streetfighter71
- ZedHead
James wrote:Still have crank cases,if any good to you.
what numbers are they in? im looking for after 21000 and 24000 max...
I will check in morn.cheers
- Z1streetfighter71
- ZedHead
James wrote:I will check in morn.cheers
Thanks James, appreciated
- Z1streetfighter71
- ZedHead
And if there are any bits left like body work and electrical let me know, might make a trip up.
I have the frame no v5 but have reg no.
My no is 07443589994
- Z1streetfighter71
- ZedHead
James wrote:My no is 07443589994
Thanks for that James but the number range is a bit far out for the bike, i have a bead on a 25,000 set, that puts them right above the number range but fairly close.
Users browsing this forum: Google [Bot] and 21 guests
