Z1000 A2 - brake light failure switch
Graham-A2
#1 PostAuthor: Graham-A2 » Wed Feb 07, 2024 10:16 am
Thought I'd ask here, but I think I know the answer. Does anyone know where to source a brake light failure switch - the one that fits into the loom under the tank. An internet search came up blank, are these unobtainable these days ?
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
Re: Z1000 A2 - brake light failure switch
#2 PostAuthor: warren3200gt » Wed Feb 07, 2024 11:05 am
I've got one last NOS one in my stash. Not keen to let it go so would want proper money for it.
Graham-A2
#3 PostAuthor: Graham-A2 » Wed Feb 07, 2024 11:44 am
Gwan Warren - you know you want to!
Seriously though, I would really appreciate it if you could bring yourself to sell. What sort of price are we talking ?
Present
Past 1994 - 2010
#4 PostAuthor: warren3200gt » Wed Feb 07, 2024 11:48 am
Let me dig it out and make 100% it's what your after. They all work the same but for some unknown reason some are slightly diffent sizes.
#5 PostAuthor: warren3200gt » Wed Feb 07, 2024 12:42 pm
G, mailed you.
DavidZ1R
#6 PostAuthor: DavidZ1R » Wed Feb 07, 2024 3:13 pm
I will have a nos switch which is for the 400, part number ends in 002, does exactly the same as the 001 unit, but just a bit bigger in size.
DavidZ1R
#7 PostAuthor: DavidZ1R » Wed Feb 07, 2024 3:14 pm
warren3200gt wrote:I've got one last NOS one in my stash. Not keen to let it go so would want proper money for it.
Wonder where you got that from :D
#8 PostAuthor: warren3200gt » Wed Feb 07, 2024 3:47 pm
Eva Peron's great great grandson. :lol:
DavidZ1R
#9 PostAuthor: DavidZ1R » Wed Feb 07, 2024 4:40 pm
:D :D :D
gray
#10 PostAuthor: gray » Wed Feb 07, 2024 8:48 pm
there's a z650 one on ebay at present £25, looks to be pretty similar to my z900 one which should be the same as your z1000 one
gray
Gray17
#11 PostAuthor: Gray17 » Thu Feb 08, 2024 10:11 am
Theres several ways of sorting this as looked into it for my own bike Z900 A4 which will use same part i believe as does Z650
1. First you could buy a NOs one like Warrens which is old but as new condition but as stated are now becoming rare.
2. You could buy a 40 year old one from elsewhere ie Ebay but after 40 or so years of being mounted under the tank with numerous hot and cold running sessions i would suspect the components may fail imminently so youd be back to square one again. Its a gamble!
3. You can make one yourself if good with a soldering iron and have electrical knowledge, parts cost about £10, theres a circuit diagram on KZ forum website only about 12 conponents needed, but obv you have to build it yourself, test it, then fit it in a small box sealed with silicone or epoxy to make watertight ( only do this after youve tested it and all working)
Pros- well its cheap, all parts are brand new so should last 40 years like original.
Cons- wont look identical to original ( but as under tsnk out of sight does that matter), relies on you doing everything as per diagram and your soldering good, if you make a mistake wont work, or maybe blow fuse etc
4. Another forum member made one for his bike and made a few more maybe he has some brand new ones still available, sorry cant remember his name but its within last 12 months try a search.
5. Do without it, whilst i suppose having a warning of bulb fail is good, its hardly a hardship to pull brake and see if rear lamp lights before riding.
Just my thoughts
Gus
#12 PostAuthor: Gus » Thu Feb 08, 2024 12:07 pm
"Set the GRINDER on it"
Gray17
#13 PostAuthor: Gray17 » Sat Feb 10, 2024 12:36 pm
Yes Gus thats the topic i remember, think i posted originally but couldnt remember member who made the sensors, senility in old age, well thats my excuse anyway!
Hope that helps original poster
Ps still havnt got round to my sensor, nor completed restoration but it is getting close! So much so i can almost taste it!! Cant wait to ride it
Graham-A2
#14 PostAuthor: Graham-A2 » Tue Feb 20, 2024 5:18 pm
Thanks all - I bit the bullet and did a deal with Warren. My soldering is pants - I've never seemed to get to grip with nice reliable tidy wiring.
Hopefully it will lead to a meet up with Warren at some stage as we've worked out that we are not too far from each other :D.
Present
Past 1994 - 2010
#15 PostAuthor: warren3200gt » Tue Feb 20, 2024 7:27 pm
Sure we'll get to have a brew, tea or beer, at some point.
