Hello to all - at last!!
zed9
Re: Hello to all - at last!!
#16 PostAuthor: zed9 » Wed Feb 14, 2024 11:01 pm
Ultim8pc wrote:
zed9 wrote:Thanks Ultim8pc carbs can be a nightmare sometimes though have set them up a few times.
Carbs were bought quite a few years ago from guy who had them just sat in damp garage for a while. Turns out No.3 had tip of air screw jammed in body which had snapped off and was a bugger to get it out without damaging body.
Are you sure you have the correct carbs for a z900? They have very chunky side mounted airscrews.
The later Z1000A1/2 had 28mm carbs with bottom mounted airscrews which often snap.
The ID stamped on the Z900 carbs is Z1200 and the Z1000A1/2 are 1025A.
They are not correct carbs for Z900 as they have air screw underneath carbs not on the side and thought they were from a z1000 though am sure they are 26mm not 28. Will have a look tomorrow see if i can find any ID on them and where its stamped.
8 Valve Mark
#17 PostAuthor: 8 Valve Mark » Thu Feb 15, 2024 12:02 am
yip, they're 26mm z1000 (as stated) a1/2 carbs not 28mm, the lack of side mounted air screws along with the underslung adjustment screws identifies them as such. Happy to be corrected. I don't "specialise" on the subject :lol:
#18 PostAuthor: Ultim8pc » Thu Feb 15, 2024 11:20 am
8 Valve Mark wrote:yip, they're 26mm z1000 (as stated) a1/2 carbs not 28mm, the lack of side mounted air screws along with the underslung adjustment screws identifies them as such. Happy to be corrected. I don't "specialise" on the subject :lol:
Cheeky!
:lol:
Sorry, I did mean 26mm, but typo-ed 28.... Corrected now.
#19 PostAuthor: Al » Thu Feb 15, 2024 11:33 am
INteresting mount for swinging arm wonder where it mounts on other side, would be hell of a wide arm and may have been for fitting rvery wide wheel and tyre for drag racing.
Thats what i thought initially but found this which shows how the outriggers might look for the concentric swingarm pivot if using it as a road / race bike with a normal size tyre. That said; as a road or race bike, given the questionable nature of the mounting of the headstock to the barrels studs, i wouldnt like to have to brake too hard :shock:
Yam2_4 TF swingarm.jpg (23.13 KiB) Viewed 3678 times
