Looking for some help/advice, please. After re-shimming the valves on my GPz, I torqued the cam cap bolts back down only for 1 to keep turning
zed1015 wrote:You need minimum 2d.
Tap and insert tool will suit any M6 x 1mm coil inserts.
Kwackman wrote:I remember from years ago, the torque for these in the manual was wrong, too high. But I THINK it was the Z1100R manual, but might be worth checking as it's around the same era, just in case.
