26mm pumper float bowl.
#1 PostAuthor: kev edwards » Fri May 03, 2024 9:00 am
I am after a 26mm or 28mm pumper number 2 float bowl the one with the pump on it, would prefer one from a 26mm set as I will be cutting g it up. Thanks in advance.
Re: 26mm pumper float bowl.
#2 PostAuthor: warren3200gt » Fri May 03, 2024 9:41 am
What you upto Kev? Got to be pumpers? I could probably scrape together a set of 26 knackered non pumpers if of any use?
#3 PostAuthor: kev edwards » Fri May 03, 2024 3:06 pm
Hi Warren, OK at this end, I trust you are good, needs to be a pumper carb 2 bowl as I'm using it as a clamp for gasket profile, had a couple 3d printed but would prefer the alloy, the picture is more explanatory.
#4 PostAuthor: warren3200gt » Fri May 03, 2024 3:44 pm
Ah, OK, now I understand. Can't help with pumpers soz!
Users browsing this forum: scott reid and 45 guests
