Indicators
Indicators
Both my front indicators are both only flashing really weak and can hardly be seen - same on both sides and the rear indicators are fine.The central display flashes correctly.Battery is newish and always on optimiser etc - any thoughts ? Thanks all
Re: Indicators
Sounds like a bad earth, check inside the headlight bowl for a good earth connection to each indicator, whilst in there also check voltage going to the + side should be same as battery voltage around 12.5v or over 13.5v when bike running. You could always run a temp wire from a good earth to the indicator stem see if that improves matters, also check the 2 bullet connectors the indicators connect to inside the bowl as sometimes can get corroded. Try disconecting the bullet and putting temp 12v to the indicator see if they light up properly then
Hope that helps
Hope that helps
Re: Indicators
Thanks that's helpful
