Clutch issue on pull away
shaggy
#1 PostAuthor: shaggy » Fri Aug 02, 2024 9:11 pm
Have a terrible noise from clutch when trying to pull away at anything above tickover .when it's rolling the clutch is fine no slipping cable is adjusted as per manual.
All plates / springs were checked and were in spec prior to building the clutch
Any ideas what is causing this please is driving me up the wall.
Re: Clutch issue on pull away
#2 PostAuthor: kev edwards » Sat Aug 03, 2024 7:31 am
Short of hearing it or a much better description of noise it's pretty much impossible to tell from here, but you may have broken springs in the basket, sticking plates, even loose sprocket.
shaggy
#3 PostAuthor: shaggy » Sat Aug 03, 2024 8:59 am
Will try and record noise on my phone and post
shaggy
#4 PostAuthor: shaggy » Sat Aug 03, 2024 11:18 am
Noise is like a metallic screech took a video but cannot add so will put on Zowners facebook page
gray
#5 PostAuthor: gray » Tue Aug 06, 2024 8:58 pm
are you running car 10-40 oil instead of motorcycle 10-40? Car stuff has more friction reducers, and will contaminate the friction plates so the clutch plates will slip more and maybe screech.
Or maybe 1 plain plate has overheated and warped
gray
shaggy
#6 PostAuthor: shaggy » Wed Aug 07, 2024 3:35 pm
This is the oil I’m using
KeithZ1R
#7 PostAuthor: KeithZ1R » Thu Aug 08, 2024 6:45 am
check your last couple of friction plates are in the correct slots
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
shaggy
#8 PostAuthor: shaggy » Thu Aug 08, 2024 9:55 am
[quote="KeithZ1R"]check your last couple of friction plates are in the correct slots[/quote]
Don’t understand that surely they all line up?
KeithZ1R
#9 PostAuthor: KeithZ1R » Sat Aug 10, 2024 8:19 am
it is possible to inadvertantly put the last couple of plates on the wrong side of the slots , take a look if im wrong so be it, if im not you can move them round one slot and the noise will cease , what do you have to lose ?
Keith
:bop :gom
mistaken.
