Z1R
Sifu
Z1R
#1 PostAuthor: Sifu » Sun Nov 17, 2024 9:13 am
I’ve just got a Z1R it’s got the 13lt tank :( 18lt tank not available anymore ? Does anyone know what the carbs are ie 26 or 28 thanks
000zeds
Re: Z1R
#2 PostAuthor: 000zeds » Sun Nov 17, 2024 10:05 am
Pretty sure they are 28mm and could also be 29mm smooth bore :idea:
Zeds-R-Us
Re: Z1R
#3 PostAuthor: zed1015 » Sun Nov 17, 2024 10:59 am
Stock Z1R carbs are VM28SS with single central fuel feed and the idle screw knob located between float bowls 2 and 3 ..
No stock factory machine was ever fitted with vm29mm smoothbores.
Smoothbores are solely aftermarket items.
Sifu
Re: Z1R
#4 PostAuthor: Sifu » Sun Nov 17, 2024 11:08 am
Cheers for the info
Re: Z1R
#5 PostAuthor: Ultim8pc » Sun Nov 17, 2024 11:27 am
The Z1r had 28mm Mikunis with an ID of:1040A
Sifu
Re: Z1R
#6 PostAuthor: Sifu » Mon Nov 18, 2024 4:02 am
Ultim8pc wrote:The Z1r had 28mm Mikunis with an ID of:1040A
Cheers mate that helps me thanks
Return to “The Bottom Shed”
