Bore size
stusco
Bore size
#1 PostAuthor: stusco » Sat Jan 25, 2025 12:08 pm
So ive stripped my gpz1100 a1 1983 odo says 14000 its a us import ,to me and people that have seen it would say its never been apart all the screws are undamaged and the olive drab is undamaged ,the bike looks unrestored.
So off with the top end and first thing I notice is the pistons look new and there are fresh looking scratches around the gudgeon pin is from a screwdriver fitting the circlips, so out with my mic 50-75 and it’s 74.92mm the service manual says 72.5mm is standard the pistons have a C on the crown ,what do think ?
Hard Road
Re: Bore size
#2 PostAuthor: Hard Road » Sat Jan 25, 2025 12:44 pm
sounds like a big bore kit !!!!!
stusco
Re: Bore size
#3 PostAuthor: stusco » Sat Jan 25, 2025 12:48 pm
It does sound big must try some maths
stusco
Re: Bore size
#4 PostAuthor: stusco » Sat Jan 25, 2025 12:59 pm
1170cc
Skid Mark
Re: Bore size
#5 PostAuthor: Skid Mark » Sat Jan 25, 2025 10:17 pm
I have a wiseco big bore on an A2. It’s approx 75mm. There should be numbers on the piston crown which will tell you what compressoion ratio you are running it could be 9.5/1if nos are 4380M07500 or if it’s 10.25/1 they are4255M07500. I’m sure there are other variations also. Also check stud diameters. This may affect oil delivery if they are larger and block was not reeked out to suit and also torque will increase if you have larger studs and higher compression. Hope this helps.
stusco
Re: Bore size
#6 PostAuthor: stusco » Sun Jan 26, 2025 9:41 am
Ill post some pictures later today once i get the pistons off and the carbon scraped off
stusco
Re: Bore size
#7 PostAuthor: stusco » Sun Jan 26, 2025 12:28 pm
My studs are 8mm
Skid Mark
Re: Bore size
#8 PostAuthor: Skid Mark » Sun Jan 26, 2025 4:16 pm
stusco wrote:My studs are 8mm
Standard so, same as mine.
stusco
Re: Bore size
#9 PostAuthor: stusco » Mon Jan 27, 2025 5:42 pm
Here is some pics of the pistons can anyone identify them?
Robw
Re: Bore size
#10 PostAuthor: Robw » Mon Jan 27, 2025 6:30 pm
Look like Wiseco pistons to me.
Rob
stusco
Re: Bore size
#11 PostAuthor: stusco » Mon Jan 27, 2025 6:36 pm
High compression piston how could i tell?
It had low compression (115-130psi) and smoked a bit before I stripped it
Robw
Re: Bore size
#12 PostAuthor: Robw » Mon Jan 27, 2025 6:40 pm
Low compression, i have high comp in mine and the dome is much more pronounced
Robw
Re: Bore size
#13 PostAuthor: Robw » Mon Jan 27, 2025 6:46 pm
As you can see these 1170 wiseco pistons have a high dome. I had 1136 on my b1 and they had a dome similar to yours and they were low comp. J
Skid Mark
Re: Bore size
#14 PostAuthor: Skid Mark » Mon Jan 27, 2025 6:59 pm
I agree with Robw. Mine look very similar to yours and are 9.5/1. Mine have two sets of no.s across the crown ( can’t upload from my phone) these appear to be laser etched so perhaps just new then yours.
Skid Mark
Re: Bore size
#15 PostAuthor: Skid Mark » Mon Jan 27, 2025 7:01 pm
Skid Mark wrote:I agree with Robw. Mine look very similar to yours ( but without the small flat on the crown)and are 9.5/1. Mine have two sets of no.s across the crown ( can’t upload from my phone) these appear to be laser etched so perhaps just new then yours.
