Z1000J wiring loom
- paul doran
Z1000J wiring loom
I am looking for a Z1000J wiring loom if anyone has a decent one they would like to sell
Re: Z1000J wiring loom
The Z1000R one is available. I believe they are almost the same.
That is wrong.
Check out the clocks and you will see some differences...
KERKER kicks ass!
elr-21 wrote:That is wrong.
It depends which year J you are talking about. The J3 has the same clocks as the R. I know this because i own a J3
- paul doran
Clocks on my J are operated by the following speedo by electronic drive from the wheel and rev counter electrically
paul doran wrote:Clocks on my J are operated by the following speedo by electronic drive from the wheel and rev counter electrically
Hi Paul. Your bike is J1 or J2 then. Cheers
Confirmed as correct, I have J3 too, speedo is cable same as later 1000R and 1100R
Eight valve grunt.
