Wanted Z1R Z1000D frame or rear section
Hi Guys.
I have a UK Z1R frame and V5 in my name but previous owner/s cut the back end off.
Looking for a Z1R, Z1000D frame or rear section.
I need the rear section to include lock mount.
Damaged, rotten, no numbers or V5 considered.
Cheers.
Gus
Cheers.
Gus
"Set the GRINDER on it"
Re: Wanted Z1R Z1000D frame or rear section
Theres been a frame on marketplace for a while , not sure if you may have seen it , its a bit ropey
https://www.facebook.com/marketplace/it ... _code=null
Thanks for that I'll keep an eye on it.
Much appreciated.
Much appreciated.
neilbarrett
- ZedHead
Have you a pic of the part you want as I've a frame I want rid of
Thanks Neil.
I'll try and get photos in the morning.
Much appreciated.
Gus
Much appreciated.
Gus
neilbarrett wrote:Have you a pic of the part you want as I've a frame I want rid of
Apologies Neil.
My frame is at a friends workshop and he died a couple of weeks ago.
As of yet I don't have access to get my stuff back at the moment.
Cheers.
Gus.
i have neil he requires back end ? from indicator plates back
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r wrote:neilbarrett wrote:Have you a pic of the part you want as I've a frame I want rid of
Cheers Compo.
Hope you are well my friend.
Much appreciated.
Gus
Al wrote:Message sent
Hi Al.
If the message was for me, there is nothing in my inbox?
Hi Gus yes the message was for you regarding a Z1R frame but it was an e-mail not a pm sorry if it didnt come through.
I have re-sent but as a pm with my phone number on it.
Does anybody know if the rear bracket on a Z1R is the same as a MK2 or have some photos for reference?
Cheers.
Gus
Cheers.
Gus
- Z1streetfighter71
- ZedHead
If you are talking the bracket that holds the light and the cowl, then yes. I have the rear tail cowl of a Mk2 and can show you it fitted to a Z1r frame.
John Browse has literally 100's of Zed frames.
